RCU Forums - View Single Post - CMP Hellcat
Thread: CMP Hellcat
Old 12-30-2006 | 10:44 PM
  #1414
bigbird007's Avatar
bigbird007
Default RE: CMP Hellcat
The reason for my assumption is simply, you have to be extremly quick to lay up the glass work in such a confined space like a fuselage mold.
That could be support for the polyester theory, they must do something to make these things so cheap! I did look this morning and there is no pinkish cast to the resin. You aren't doing the custom cockpit I see, the sierra air tank is at least as big as Robarts and won't fit anywhere up front with the custom cockpit in. Luckily it weighs practically nothing cause it has to go behind the wing saddle in the fuse.
I like your cowl, how did you do the vanes in the "smile"
I sure don't see any difference, from your pictures, in the construction between the knockoff and the real thing.
