RE: HL Tiger W.I.P.
The work you have done looks great! Looks like you are building a near duplicate of the Wittmann early tiger. You should turn the coupola for it to hinge in the correct position. Also, if you are using hull smoke launchers, the ones on the turret should go as they moved them onto the hull to lower the chance of the smoke grenades being set of accidentally by small arms fire to the clusters on the turret, blinding the tank. David Byrden's excellent tiger 1 site goes over just about every detail imagineable, but you can specifically look up his corrections for the cyber hobby wittmann kit that shows the proper coupola angle and the smoke grenade location points(yours look pretty much dead on).
The fenders are going to look awesome after painting!
See the links 'cyberhoby 6350 coupola' and 'cyberhobby 6350 corrected instructions' for an exploded view of the hull top showing the s-nade launchers on the hull. You can navigate back to the home page for a TON of information.
[link=http://tiger1.info/models/products/CH6350.html]http://tiger1.info/models/products/CH6350.html[/link]
Which PE set did you use for the engine deck grills?
