RE: gst 7.7 ? about fuel
Adarsh, I live in the Sonoran Desert In Arizona. I Had A huge Problem with dust and my airfilter(cleaning it after every run) When I moved the air filter forward(right behind the front shock tower) I found myself forgetting to clean the airfilter, having to clean it every 6 -7 runs. Here are pictures of the simple mod I did that changed the way my truck got fresh air!
I also added a couple of shots of my swaybar installation on the front suspension. (3.5MM in The Front And 4MM In The Rear Seems To Work Very Well)
I hope this helps!!!Have Fun!!!!
