RCU Forums - View Single Post - Aileron and elevator mix glitch?
Old 01-01-2007 | 06:48 PM
bruce88123
Default RE: Aileron and elevator mix glitch?
ORIGINAL: Geistware
He said he had the T6XA not the 6EXAP. I don't think the T6XA has that feature but I could be wrong.
ORIGINAL: bruce88123
http://www.futaba-rc.com/manuals/index.html
On pg 21 of the manual you will find in the above section there are instructions for making the electronic change over to Mode 2. Then with the ratchets set properly you SHOULD be all set.
QUOTING:
Changing the 6EXAP stick mode
The transmitter may be operated in four different stick “modes” (1, 2, 3 & 4). The modes determine the functions that will be operated by control sticks. Currently, the transmitter is in “mode 2” and should be left in mode 2 unless you are an experienced flyer and have learned to fly in a different mode. In mode 2, the right control stick operates the aileron and elevator and the left stick operates the rudder and throttle. This is how 99% of Americans fly their models.
To change the mode, simultaneously depress the MODE and SELECT keys, then turn on the power. The current mode will appear on the LCD screen. Push the DATA INPUT lever up or down to change the mode. If a mode is selected that moves the throttle control to the right stick, the throttle detent mechanism will have to be moved as well.
You are partially correct Geistware. I had the wrong manual.
It's on page six (6) of this one:
http://www.futaba-rc.com/manuals/notes-6x.html
Thanks for noticing my error.
