RCU Forums - View Single Post - 4* 60 with sheeted leading edge and turtle deck
Old 01-01-2007 | 09:44 PM
Eagle Flyer
My Feedback: (84)
Default RE: 4* 60 with sheeted leading edge and turtle deck
All but finished with the covering. Just have to trim the wing some and do the ends of it. OK I know it looks a little bright but that is just what I wanted. I'm not too artistic. The balance came out nice. All I had to do was move the servos all the way forward and add a heavy hub using my old engine mount. I could have got a new one and moved the engine forward about 1/4 " but decided not to mess with it. Also found that my new Saito 125 will bolt right in and weighs the same as the TT 91 in it now. So later in the summer I may advance to that. I went with a removable servo tray so I could remove the oversized 16 oz. tank if need to. Also by putting it all the way forward it holds the tank in place with some foam in between. For some reason pictures won't work at the moment so I will post later. OK pics are working. I was pondering the canopy thing and remembered one I had. It came from an expired Futana 40. It's turned around backwards and trimmed a whole bunch. I kind a like the looks of it except it has a few scratches on it. But that doesn't bother me too much. They are always scratched it seems like by the time I get them mounted. Several coats of wax will do wonders for them.
ID:	588688   Click image for larger version
ID:	588689   Click image for larger version
