RE: Brison 2.4 problems
Last night was the first time I had A chance to look at it. I found the pick up was loose enough to slide it back and forth and it was sitting about half way over the magnet?? I set that and tightened and will double check the timing sometime today then go through the fuel system. It took some effort to slide the pick up so it isn't like it was bouncing around or anything.
Here is A question for you guys. Why when I get an engine that was test run and all set up from the dealer, I got this one from Garry direct but I have bought from others like RC Showcase, I use the same prop and fuel, they never seem to run well. They have all needed tuning. This one has been A problem from day one. Just wondering?
