RCU Forums - View Single Post - Brison 2.4 problems
Old 01-02-2007 | 01:13 PM
adrenalnjunky
My Feedback: (18)
Default RE: Brison 2.4 problems
Not 100% sure what you are meaning, but there are always issues that can make a difference in how an engine runs that are determined by the atmospheric conditions that an engine sees.
If the dealer/manufacturer test runs the engine in a climate controlled room, or even outdoors with very low humidity at 3000 ft ASL, and then ships it to me in Louisiana at 75ft ASL, and I try running the engine at our typical 75% humidity on a 55 degree day - I'm going to expect the engine to respond differently if the needles are set the same. I'm guessing the engine would be running a little lean in my location.
Also the mounting in the cowling can cause some pressure changes that act on the carb differently, and may require some adjustments to make the engine run well in-flight. It's always something.
