RCU Forums - View Single Post - Cen GST 7.7 3rd gear
Old 01-02-2007 | 05:34 PM
jombo's Avatar
jombo
Default RE: Cen GST 7.7 3rd gear
ORIGINAL: The Real Dogman
RangerXlt72
Sometimes 2nd gear engages so quikly after take off you done hear it and you will only hear 3rd gear engage, but you should be able to lift the truck while running and throttle up and feel as well as hear the the 2 shifts(there is only 2 since it is in first when the clutch engages and 2nd is the first shift you hear/feel and 3rd is the sencond shift you will hear/feel)
I Hope This Helps
Have Fun!!
dogman is correct, reduce the 1-2 shift and you will hear and see the 2-3 shift. 1st reves up very fast so i have mine set low so i can wheelie more and climb some steep hills and rocks.
