RCU Forums - View Single Post - Tiger 60 Build Thread
Old 01-03-2007 | 06:00 AM
  #59
krossk's Avatar
krossk
My Feedback: (27)
Default RE: Tiger 60 Build Thread
ORIGINAL: overbored77
Quick question on my tiger 60 build, I am going to build a framed up elevator instead of those balsa blocks. Do you think I sould add an extra 1/2- 3/4 inch of TE material to the rudder and elevator?
From what I've read, I'm not sure 1/2-3/4" will make much of a noticable difference on the rudder. Typically, rudder mods on the Tigers are more like 1-1/2 to 2". The elevator might make a difference with 1/2-3/4", but I can't speak to how much yet. If you've been following my build, I effectively added area to my elevator by moving the hinge line forward and eliminating the trailing edge tips from the stab.
Also I wanted to clip one bay off each side of the wing. Can I just clip the first bay off each side and adjust my sheeting, or do I have to do what you did Kross?
If you are just going to eliminate a bay, do it from the outboard end, not the middle. You need to keep the inner rib spacing so there is something to glue the outer edge center sheeting to. I did mine the way I did because I was concerned about maintaining the strength of the wing as I intend to use this plane as a pattern trainer, so the wing will more than likely be stressed beyond the loads incurred by average sport flying. Also, if shortening the wing you might want to consider moving the aileron servo mount inward to keep the linkage close to the center of the aileron.
