RE: Split elevator glitch.
Hippy,
I don't know what happened to your post... But just as an update. I did fix the glitch by replacing the 3305's with HS5625's. After examing the the 3305's I discovered that the slow / weird servo had a nick in the sheathing of the ground wire.
I not sure if that cause the problem but I do intend on replacing the lead and retesting the servos at a later date...
Good Luck,
Hibrass
