RE: Towing a trailer with a Dodge Caravan
Should tow the trailer just fine. I have an older Caravan, '92, with a 3.3 and I have towed quite a few trailers with no problems. As far as the trans, check your owners manual. On some models, you need to tow in Overdrive, or others in Drive. My manual specifies to leave the trans in overdrive when towing. Works fine with no problems and downshifts at the right times.
