RE: Help with Matrix RTR
Why did you replace the carb needles? Check to see if your needle setting are out of whack> If the main needle is way to rich OR lean it will die when you give it gas, lean it out a half a turn and see what happens, better or worse then go back to where it was now richen it up half a turn and so on.... Tho see if the setting are off.
