RE: Aileron and elevator mix glitch?
Hi,
I have changed some of the settings and decided to try a new profile, (model 3) I can select I think up to 4 different models of the samr type (planes, copters or gliders but not one of each) I have a new receiver a JR synteresized 7 channel that I have decided to fit to the plane for safety's sake - no crystal failure problems. Then go about sorting out the functions on the TX to see what works and what doesn't, currently moving the Ailerons causes the throttle to work, the rudder works off the elevator output, and the ailerons work from the landing gear switch, so I have some work to do. I'll let you know how I get on.
THanks for your help so far, I also found the manual on another site and I still have a hard copy in my hobby room, I'm a bit distracted at the moment with the England - Australia test match for a few days.....So i'll let you know how I get on over the next little while.
Thanks again for your advice.
Andrew
