RE: Proper engine shut down/clean up procedure?
Nothing to add excepting I'm a proponant of using after run oil. I use Marvel's Mystery Oil. Some people fear after run oil will destroy the O-ring used as a seal between the carb. and crank case. I guess I would rather replace this O-ring seal then damage the internals of the engine (bearings, rings, etc).
