RE: 91' Cap
The cap Cap came out at 20lbs & 6oz, it has 2 mpi switchs with built in 6 volt regs 2, 2400 fromeco batts a 24 oz dubro tank, hanger nine hardware with central hobbies carbon fiber/ titaium rods. The motor is a 3w-75ius a 2400 fromeco & 5.1 reg and a jr heavy duty switch, Dave Brown 3.5" spinner with lighted back plate, 24x10 3-w wood prop. Servos are 5645 hitec's in the wing,5955 tg on the elevators,and 1-5745 1/4 scale digi on rudder with Don,s hobby shop pull-pull set up. There is no pilot,dash or wheel pants I hit the CG dead on with out adding weight any where just moving the batts around.
will send pick of setup on inside if that will help.
