RCU Forums - View Single Post - Seagull Edge 540 w/ Evolution 100
Old 01-04-2007 | 09:53 PM
aussiesteve's Avatar
aussiesteve
Default RE: Seagull Edge 540 w/ Evolution 100
Check to see if the o'ring is located under the carb - there were a number of this engine that had it missing.
Apparently there were also some that had a leaking HS needle around the threads - they would introduce air. Apparently this was often fixed by putting some flexible pipe over the needle assembly rr by the use of sealing paste on the threads.
