RE: GST 7.7 Stuttering
Since the car is new I would still run it fat at least on the bottom end wich I run .9mm out from flush.
The car is having a stutter when the clutch is kicking in... which most times yes- it can be solved by leanin the top end a bit
You could back out the screws a 1/8th of a turn or so to get it to decide on second with more confidence as well
