RE: Robart Hinge Points
I also think its a good idea to do one surface and let it dry before mating to the other. This way all of the hinges are fixed at the exact same depth and pivot points. Then you can attach the movable surface without disturbing the hinge points, takes a little longer but i have been stung doing it all in one step and ended up with a binding surface.
V..
