ORIGINAL: Dave Shadel
We can do the Hanno along with the SF/RF. The ID and OD of the sleeves is the same as are the pistons. It is likely that we will not do these in ABC, but in AAC. Aside from them being lighter in AAC, we have found them to be more durable than ABC, so you get a better product.
Are rods still available thru Tower/Hobbico/etc? It is always advisable to change the rod when you install a new P/C in an engine. If rods are an issue, I suppose we can make them too.
Looks like we are getting some interest on this. Keep beating the bushes so we can get an order together.
Dave-Performance Specialties
I want to add that these parts will be of the highest quality. The quality level of parts will be like what you would see in the high end engines like the Nelson engines.
