RCU Forums - View Single Post - engine wont idle
Old 01-05-2007 | 10:01 PM
ASSOCIATED_DRIVER's Avatar
ASSOCIATED_DRIVER
Default RE: engine wont idle
the only way it stays on is with quite a bit of throttle and then it starts to move.
Sounds like the idle adjustment is off. Open it up a little bit. There should be a 1.mm minimum gap opening on the carb to start off.
