RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
engine wont idle
Old 01-02-2007 | 02:15 PM
Default engine wont idle
hi all!!
gave my lightning pro a good once over yesterday by taking most of it apart and cleaning and putting a few drops of after run in the engine thinking i wasnt going to run it. got from work this evenin and decided i wanted a backyard bash so went to start it and it would start with a blip of the throttle and would then die instantly!!! the only way it stays on is with quite a bit of throttle and then it starts to move.
i am fairly new to nitro cars and yes i did break on the engine properly but im not so sure now as to what to do!!
any help asap is greatly recieved!! thanks!!
Old 01-02-2007 | 03:24 PM
Nitr0-is-Deadly's Avatar
Default RE: engine wont idle
it sounds like ur running it to rich! after you broke the engine in did you tune it? do this it sounds like ur engine is getting to much fuel and cant ignite causing a stall/turn off
do you know what the high speed needle is?
turn it clockwise 1/4 a turn untill the engine runs right and isnt overheating
or do the same for your low speed needle if this doesnt improve it.
ALSO could be ur glow plug..try changing ur glow plug b4 u try to set the needles
Old 01-05-2007 | 08:18 AM
cheers!! i tried again last night without changing anything and it wouldnt even start!! dont know if this helps with your diagnosis?? i will try again tonight when/if i finish work lol!! and if it doesnt do anything then, i will have to go to my lhs which is a bit of a trek!! : (
Old 01-05-2007 | 10:01 PM
ASSOCIATED_DRIVER's Avatar
Sounds like the idle adjustment is off. Open it up a little bit. There should be a 1.mm minimum gap opening on the carb to start off.
