RCU Forums - View Single Post - Nexstar problem - Loose horizontal stab
Old 01-06-2007 | 06:57 PM
chris750
Default Nexstar problem - Loose horizontal stab
Hey guys,
I'm still trying to set up my Nexstar and I've come across a problem when installing the horizontal stab. When installing using the screws provided the stab won't sit securely, but it can wobble slightly from side to side.
Basically the screws slide in from the bottom of the fuselage and up through 2 holes in the stab which is meant to secure it. The screw's are tapered, and the rear screw is fine because it slides up far enough for the WIDE part of the screw to be through the hole, which is a snug fit. However for the front screw, it only slides up enough for the tip of the screw (the skinny part) to be through the hole, which allows for left-to-right movement. Even after I install the fin it still moves.
Any ideas on how I could fix this? Or has anyone else had the same problem?
I'd really like to find a solution without having to strip the covering and gluing it, if possible. I hope theres another way around it.
Would love to hear some suggestions. Thanks!
