RCU Forums - View Single Post - Nexstar problem - Loose horizontal stab
Old 01-06-2007 | 08:55 PM
chris750
Default RE: Nexstar problem - Loose horizontal stab
ORIGINAL: i live for 3D
I had that same problem with my avistar. Put the horizantal stab on and with a sharpie draw a line were the horizontal stab meets the fuselage on both sides. Then cut out all the covering in between those two lines put some 30 minute epoxy on it and slide it back in.
P.S. do it to the top and bottom.
Tony
Thanks, I realise this will work but like I said I'd prefer not to glue it if possible.
