RCU Forums - View Single Post - Nexstar problem - Loose horizontal stab
Old 01-06-2007 | 08:56 PM
chris750
Default RE: Nexstar problem - Loose horizontal stab
ORIGINAL: bruce88123
Is the front hole simply too small and if you enlarged it slightly would all be OK?
No, actually the opposite. The hole is too large, thats why i get the movement. If the hole was smaller, it would be same diameter as the TOP of the screw which means it would be a tight fit.
