RCU Forums - View Single Post - Nexstar problem - Loose horizontal stab
Old 01-06-2007 | 09:52 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Nexstar problem - Loose horizontal stab
A picture would help a lot if you can manage it.
Ok, let me ask this. Even though the front screw is loose in the hole, does it still securely thread into the vertical stabilizer? Does it get enough thread on the vertical stabilizer to tighten it down against the fuselage? I understand that you still have a little bit of wobble in the stabilizer because the hole is bigger than the screw, but other than that is it tight??
Ken
