Thanks Dustin. Yep, I will have to double check my LSN setting. I only get 1 or 2 pulls before the handle starts jerking back when I try to pull start the motor. It must be quick flooding. I have not had much luck with pull starts. I agree that pull starts is great because you dont have to carry around the drill starter. Its just frustrating as I always get sore knuckles and fingers from the pull start jerking back. Thanks for the info. I will try to clean/flush out the engine and reset the LSN. Try Try Again.
