RCU Forums - View Single Post - Nexstar problem - Loose horizontal stab
Old 01-06-2007 | 11:01 PM
chris750
Default RE: Nexstar problem - Loose horizontal stab
ORIGINAL: RCKen
Do you have an O-ring or something that you can put around the bolt that will secure it inside of the hole? Do this and it will keep it from wobbling around in the hole.
Ken
I dont have an o-ring but I do have sticky tape! I've wrapped it around the end of the screw therefore increasing the diameter to match that of the widest part. This worked in terms of securing the horizontal stab and stop it from moving, but is it a good enough fix ??
I'm also now wondering about the gap underneath the vertical fin as seen in the pic before, is this a problem?
