RCU Forums - View Single Post - Nexstar problem - Loose horizontal stab
Old 01-06-2007 | 11:50 PM
fayrwerks
Default RE: Nexstar problem - Loose horizontal stab
Hi Chris,
I had the same problem with my nexstar and found that if you CAREFULLY put some drop of thin CA on the horizontal stabs rear hole and some 5minute epoxy on the front holes (just be ready with a fine sand paper) you protected the balsa from exhaust residue and strengthen the mounting holes. and still you have the the option of removing the tail for transporting or storage.
