RE: E-Flite Blade CX2 lower blade tracking problems
Mine is the same way actually. about 1 cm off. I thought there was an issue when I had changed blades, because I initially had problems with control after the change. I ended up having to recenter my servos and that solved my control issues, and I have a rock-solid hover now. But the lower blades still appear to be off slightly.
