Thanks Don and the chin is up and I have high hopes that everything I have done has cured the problem. The one time I got the engine to run right it was really A power house.
That ignition does clean it up but I always liked the looks of mine as it is. It had A better shine under the tree then the rest of the decorations.
I did have A BAD RF problem at first and went through everything and nothing helped. I went to A new PCM RX and problem cured. Move forward in time about 6 months and I was using that old RX to build A crash box and the antenna fell off in my hands!! Glitch found.
Sometimes when going through everything it should be taken A little farther.
What can I say ?? OOPS!!
