Originally posted by Slug
My flight box, varnished 20 years ago, is holding up just fine.
Simon.
.Thanks Simon,
I never knew that varnish would hold up to the fuel chemicals.
I make canoes and kayaks and use varnish because I can remove it very easy with a light grit sand paper and found in some places it's pealing off.
I'll give it a try since it is cheaper.
If needed then I can epoxy right over it.
Thanks for the post
