RCU Forums - View Single Post - Ballistic Pattern ABC Engine Liners
Old 01-08-2007 | 04:07 PM
SynergyPilot
Default RE: Ballistic Pattern ABC Engine Liners
ORIGINAL: Dave Shadel
We can do the Hanno along with the SF/RF. The ID and OD of the sleeves is the same as are the pistons. It is likely that we will not do these in ABC, but in AAC. Aside from them being lighter in AAC, we have found them to be more durable than ABC, so you get a better product.
Are rods still available thru Tower/Hobbico/etc? It is always advisable to change the rod when you install a new P/C in an engine. If rods are an issue, I suppose we can make them too.
Looks like we are getting some interest on this. Keep beating the bushes so we can get an order together.
Dave-Performance Specialties
Hi Dave,
Wow. A lot of vintage pilots out there. Count me in for the following:
2 x Liner, Piston and Rod assembly for the O.S MAX .61 SF ABC-P.
3 x Liner, Piston and Rod assembly for the O.S. MAX 61 RF ABC "HANNO SPECIAL".
Delivery to Stockholm, Sweden where I live should not be a problem I guess.
Have you managed to count all of the orders yet ?
With Kind Regards,
Gunnar
