RCU Forums - View Single Post - Nitro models pusher Bobcat?
Old 01-08-2007 | 06:47 PM
  #859
AGR413's Avatar
AGR413
Default RE: Nitro models pusher Bobcat?
CrashPro,
Fantastic, thanks, I hope it helped you out. Thanks for posting the picture that's pitts does not look bad on there. I just could not imagine the scale until you posted the picture.
Make sure you have a dual rate setup and are able to go to high rate elevator if you need to. I ran out of elevator on my maiden and was so glad I had set up the high rates.
A word on the stock landing gear and and landing. I have had no problems until I let an "expert" pilot friend fly my Bobcat. It was handling so nice he was puttering around really slow and tried to land it, you can't do that with this plane it will bounce and bend the landing gear. I have always set up for a nice glide and bled it out the the very end increasing up elevator all the way. If you land this plane smooth the stock gear are fine but if you ever bounce it get ready they will bend. Oh and the plastic hubs on the wheels will shatter. lol
PS Good job on the build..I think your build is cleaner than mine.
PSS I hope you like speed. [X(]
