RE: carb needles
The idle is right below the air filter... low end is usually found on the end of the throttle slide /rotary and high end-overall is ussually the big gold sleeved screw... they all work together.... your on the right track I ussually run fat and then lean in to desired perfomance... ussually leavin the bottom a little fat and raising the idle a hair.
