ORIGINAL: notch
Try a fresh gasket and a wrap around spring... are you using the two spring set-up to hold the manifold on?
Thanks guys I will first try the using two seals if un-successful I will try the high temp gasket maker.
I am currently using a wrap arong spring, ditched the two spring set ages ago...
