ORIGINAL: UKIE
ORIGINAL: DscottM83
ORIGINAL: UKIE
ORIGINAL: DscottM83
I dont get why they dont just make one that can plug into the wall, "seems pretty standard" under $150.
I know what your saying.
Check out this power supply. A very good deal if you ask me. I payed close to $80 for the one I have.
http://www.etronics.com/product.asp?...re=&catid=4071
So is that correct, there really isnt a charger for these Great Planes LiPo 11.1V 910mAh 3S 15C batterys for under $150? Whats DC mean, i can charge it off my car Battery? Also will that power supply work with "Great Planes LiPo 11.1V 910mAh 3S 15C Discharge Deans & a Great Planes PolyCharge Lithium Polymer DC Charger"
THANKS!!!
This charger is probably the best bet for cost savings. Between this and the power supply I provided the link for, you will into this for about $75..
http://www2.towerhobbies.com/cgi-bin...?&I=LXHNW5&P=M
D.C. stands for Direct Current. The power supply converts your household 110 V. A.C. (alternating current) to the D.C 12v. needed to run the charger. Very simple set up that works well. and IMO is pretty cheap..
Ok cool i already have this charger/battery on the way from Tower. So that " Pyramid PS-14KX Regulated 12V 14Amp Power Supply" you showed me in the link will work for sure with the "Great Planes LiPo 11.1V 910mAh 3S 15C Discharge Deans & a Great Planes PolyCharge Lithium Polymer DC Charger"? Just making sure. This battery stuff adds up quick, and i went the cheap route
