ORIGINAL: DscottM83
haha thanks for the quick replys, you must be busy at work also
The charger says "250 and 500 and 1000mA selectable charge current" which should i charge that LiPo @? Do i need any special connector to connect the charger to the power supply?
heheheh. yes I am work, and the college I work for has not started yet so I do have some free time.
You''ll have to see what they give you for leads with the power supply ( if they give you any at all). If they don't give any, just get some banana plugs with a lead on each. Strip one end end to expose the wire and clip the alligator clip that is on your charger to the banana plug lead. WHALA! Charge to your hearts content.
As far as the Mah charge rate setting on the Great Planes charger I am not sure. Maybe someone that has this set up can chime in on what you are supposed charge the Lipo at. I am also interested to know what the setting should be as this is the route I will be going too.
Good Luck and let us know what your outcome is.
