RCU Forums - View Single Post - WHAT'S WRONG WITH NITROPLANES.COM?
Old 01-10-2007 | 03:33 PM
  #254
nitrostaff1's Avatar
nitrostaff1
Default RE: WHAT'S WRONG WITH NITROPLANES.COM?
ORIGINAL: aironut
Subject YAK-52 -55" wing
First you did a good job on the instruction manual this time.
Second the hardware package is a desaster ,no hex nuts for the bolts,no set screws for the wheel collers,no tail wheel wire,& no spinner
(my first YAK had a spinner)also the tail end of the fusalage where the stalizer fits in was not glued together and was crooked. Stab was not parallel with the wing,had to sand like mad to get it to even come close to parallel with the wing,also the hing material is so stiff its tough to bend and that puts a bigger drain on servos & battery. I still think its a good looking bird and just the right size for my needs.
By the way what happed to the $50.00 credit you said I would get on my next purchase? this is my third buy from you...heres the order numberfrom the first YAK...yhst-17210252890263-7917.......Lee
PM me the emails about the $50...I'll get an answer from the mfg regarding your concerns
