ORIGINAL: tigerdude426
What else can I put in the power panel opening besides the usual power panel?
But - I already purchased my glowplug ignitor, fuel pump system (pictured above) and my 12volt starter (not panel ready).
Should I still purchase and install the power panel with the belief I will upgrade???
Or is there something else that would fit there that would be equally as useful and look good there?
A field charger is about the same size as a power panel and is a useful item. If your starter has alligator clips, you can install some simple terminals to connect the wires. Or you can replace the clips with a plug and install a receptacle to plug it into.
