RCU Forums - View Single Post - gst 7.7 clutch bell
Old 01-11-2007 | 08:59 AM
The Real Dogman's Avatar
The Real Dogman
Default RE: gst 7.7 clutch bell
Witaker what makes it SOUND tight? An easy way to tll if it is tight is to raise it up off of the wheels and rotate the wheels in a direction that makes the gears and clutch bell spin..if the gears and clutch bell spin freely then your mesh is not too tight..If everything is still tight then spin the clutch bell only by hand. if that seems tight then the Xmsn is ok but the clutch bell is tight..you could also just spin the wheels in a direction that clutch bell doe not spin..if it seems tight then the xmsn is tight...get it? not sure I did....
Hope this helps-Have fun!!
