RCU Forums - View Single Post - BEGINNER'S BUILD - Tower Trainer .40
Old 01-11-2007 | 11:22 PM
  #135
shd3920
Default RE: BEGINNER'S BUILD - Tower Trainer .40
Aileron servo tray permanently installed with epoxy. Had to enlarge the opening so that the servo wire can come out, there was no space for the wire to squeeze out of so I had to carefully enlarge the opening. Then I reinforced the inside sheeting near the servo opening with scrap 1/16" sheeting as instructed. Then I added a piece of hardwood sheet at both ends of the servo opening to accept the servo screws better.
Tomorrow its off to do the top sheeting. And maybe by then I will find my Slot Machine and start doing the hinging.
If I can't find it I will have to set up the engine mounts which have not been drilled yet for my engine.
About time I clean my work table AGAIN so I can work better. And clean up the surrounding area and maybe I will find the Slot Machine.
