RCU Forums - View Single Post - robart pin points on DP330L
Old 02-01-2003 | 09:14 PM
santi's Avatar
santi
My Feedback: (32)
Default robart pin points on DP330L
i installed 4 pin points on my rudder last night. Boy was that a lot of work just peeling the ultracoat back then cut the sheeting off just to be able to get that balsa stock back there done that to the ailerons also. But now.....Should i do my elevators? I put in soo much time with the ailerons and rudder making sure that it dont look obvious at the field. Im thinking about putting 3 each elevators. These pin hinges are much more stronger than the stock ca that DP provided and im thinking that 3 would'nt hurt. But, I will still wait to see if anybody out there well tell me so......Until then I guess I will work on something else..
Santi
