RCU Forums - View Single Post - robart pin points on DP330L
Old 02-03-2003 | 06:34 AM
Flymyplane
My Feedback: (24)
Default OH!
Hey Wuudogg,
Glad to see you are making progress on the new DP! Thats a good point about the robarts. I have an H9 Cap 1/3 scale, that I had to cut a couple of the points down, to fit due to the tube. Do you think that there is enough room to cut the robarts down some on the DP? How much of the robart fit before it hit the tube? Oh well, doesnt, really matter now does it! ha! ha! You and I both have our elevators CA'd together. Im guessing you used the provided CA hinges by DP? I did robart hinge my ailerons using 6 pins per aileron, but had to add the extra balsa blocks! Dont forget to do that! Good luck with the DP! It sure is a pretty plane!
