robart pin points on DP330L
Hi Santi,
Thanks for the info! You are replacing your CA hinges with Kletts, Im wondering how many CA hinges you had initially on the Elevators and rudder? Did you have 3 or 5 CA hinges installed before? Also, which or how many CA hinges failed you and which surfaces (only elevator?).
One more thing, were the CA hinges that you used before, the stock DP CA hinges that came with the kit?
Thanks!
