how many CA hinges you had initially on the Elevators and rudder?
I initially had the 5 in there.
which or how many CA hinges failed you and which surfaces (only elevator?).
I had one on the end of the ailerons and one on the elevators.
i normally do a preflight check on the hinges before each flight and when i pulled i noticed a little play underneath the sealed top and bottoms of the elevators and ailerons.
were the CA hinges that you used before, the stock DP CA hinges that came with the kit?
Yes.
Where are you all getting your klett hinges?
LHS=Local Hobby Store
Santi
