RCU Forums - View Single Post - robart pin points on DP330L
Old 02-05-2003 | 07:14 PM
santi's Avatar
santi
My Feedback: (32)
Default robart pin points on DP330L
flymyplane,
When you do decide to use the klett hinges on the elevators there are about two each elevators that you will need to trim down. When you do, you will cut past the 3 little holes. Be sure to drill more little holes as the epoxy will fill those holes. then insert. Be sure to grease the hinge portion so the epoxy will not adhere to the hinge. Good luck. Tell me how it went....
Santi
