RE: NEED HELP WITH HYPER 8
Does it even splutter before dying? Usually the settings on new engines are far too rich. The low end needle usually needs leaning a touch to get it running. Leicester is rubbish for modelshops. Also have you touched the needles so far? if so did you touch the middle needle? if so it might need resetting, as these shouldn't be touched till you know exactly what you're doing.
