RCU Forums - View Single Post - CMP giant scale Zero build
Old 01-13-2007 | 07:22 PM
paladin
My Feedback: (9)
Default RE: CMP giant scale Zero build
I’ve reinstalled the front LG mounts 3/8 of an inch further into the wing, then plugged the holes that made in the ribs with scrap peaces of hard wood. You will see that one of the holes is not plugged yet.
I use a ruler under the strut (that will be shortened later) to decide the size tire I can use. In order to use a 4.5 in wheel I would need to further cut away LG mount to allow the system to rotate to that point. So after verifying that the other wing will fit a 4 in wheel, will do just fine and be an inch above what came with the kit..
Last picture shows the forward rack of the gear with the new front LG mount location.
Joe
ID:	597189   Click image for larger version
ID:	597190   Click image for larger version
ID:	597191   Click image for larger version
