RCU Forums - View Single Post - Emcotec 2001 RV
Old 01-13-2007 | 10:13 PM
Seeplaner's Avatar
Seeplaner
Default Emcotec 2001 RV
Not needing to go where someone has gone before me, does this idea sound reasonable & has it been done & cause no problems.
This is my first Turbine and first use of a powebox type device.
If I run 2 x 6 cell NiCad or NiMH into the Emcotec, then is it OK to run the Jetcat ECU from the unregulated output from the Emcotec?
This means 2 large Batts instead of 3. (kero start P-160)
Also distance to seperate the ECU & the Rx and/or Turbine pump, which is ever likely to cause more rf problems?
Any help is welcome.
