RE: Emcotec 2001 RV
What is the output voltage at the unregulated point?
Keep the pump and ECU as far as possible from the radio gear. I usually try to run the turbine electronics & pump down one side and the radio gear on the other side!
Personally I'd use the 3rd battery - the kero start and pump eat up battery capacity (use lipos if weight is a problem)!
